Author Topic: Thurlby Thandar PL310  (Read 13857 times)
Offline WarSim
Re: Thurlby Thandar PL310
« Reply #25 on: July 17, 2014, 03:15:20 pm »
The channel is Element14/Newark/Farnel.  Somewhere the errors where made.  Some where in the line the wrong part was put in a box labeled by TTI.  Somewhere the item box was crushed so much that chassis was bent and the cover rivets popped.  All the participant in this process have a good reputation.  That is why I had a CAR started.  This is two of the three errors made in this purchase process, don't worry there is plenty of blame to go around.  I am not looking for someone to blame I just want to know why and give the error makers the chance to find a solution to keep it from happening again.  Because I can wait for an answer before reordering I will.
I will count the positive portion of your response as a vote of confidence for TTI.
Sent from my iPad using Tapatalk
