Can you provide some context? What are the surrounding components? Is the "8" likely to be a year code? Can you identify the Vcc and Ground pins?
The IC appears to be driving 4 inductors, but there are no feedback pins. :-?
Could it be an ESD protection diode array?
3.0SMJC series are TVS diodes.https://www.mouser.com/datasheet/2/1057/3_0SMCJ_SERIES-1865170.pdf
What is the device and what is the output port connected to?
Similar to this?https://www.ti.com/lit/ds/symlink/tpd4s009.pdfBTW, could the device be an ECG? That could explain the "SKIN" on the PCB.
You have some interesting jobs.
