Author Topic: Isn't it ESR Meter showing correct?  (Read 4631 times)
Offline SavethedayTopic starter
  • hobby technician
« on: October 11, 2014, 09:32:10 am »
Hi
I buyed an used ESR Meter from ebay.After turning the device on.it shows the number 1 in display.When i try to measure capacitors it allways shows numbers greater then 1.3 or higher. Isn't it suppose to show numbers below 1 ?
thanks.
« Last Edit: March 28, 2023, 07:28:50 pm by Savetheday »
Offline nitro2k01
Re: Isn't it ESR Meter showing correct?
« Reply #1 on: October 11, 2014, 09:47:03 am »
Note the position of the 1. The 1 you are seeing is not the number 1, but means "overload", too high resistance to measure (open circuit).
1.3 ohm is a reasonable ESR value for some capacitors. Which type of capacitor did you probe? (Value and voltage rating.) What happens if you short the probes?
Offline kripton2035
« Reply #2 on: October 11, 2014, 11:30:56 am »
seems to be the elektor esr meter from september 2002
here is a link to the original article and the method for calibrating.
http://kripton2035.free.fr/commercial%20esr/esr-elektor-sept.html
  • hobby technician
« Reply #3 on: October 13, 2014, 12:21:45 am »
Thanks but i didn't get it.Is It still working and usable?
Offline kripton2035
« Reply #4 on: October 13, 2014, 06:05:49 am »
yes first link in the description - just downloaded again it's working.
