Author Topic: TV power connector repair  (Read 1016 times)
Offline mintsoftTopic starter
« on: December 14, 2018, 11:34:29 pm »
Hey,
I'm attempting to repair my parents TV at the moment, there's a physical connector issue with the DC jack I think as I can hear it crackling and it's very sensitive to movement of the power supply.
It's not a normal socket however, I think it's a 7mm female socket, PCB mount, however it's vertically mounted on the PCB (see attached for photo). I've been unable to locate a replacement component from my usual list (rapid, rs, farnell) however I assume I don't know the magic words to put in the search! Does anyone know where I could source a (UK preferred) replacement socket?
The TV in question is an LG 29MT31S if that's of any use.
Thanks,
Rob
Offline Shock
Re: TV power connector repair
« Reply #1 on: December 15, 2018, 12:14:50 am »
Offline coromonadalix
« Reply #2 on: December 15, 2018, 01:53:15 pm »
Seems the good one ?
Maybe take some rings diameters and inside hole measurements and ask the seller ?
« Reply #3 on: December 16, 2018, 11:50:30 pm »
Yeah definitely looks like it; I've ordered some. I was hoping they'd be standard so I could source them from somewhere UK based. I guess that's just not the way things are built these days :(
