Author Topic: Repair: Rohde & Schwarz FSEA 20/30  (Read 2120 times)
Offline BicuricoTopic starter
  • Country: pt
    • VMA's Satellite Blog
« on: October 29, 2017, 03:55:03 pm »
Hello,
My next repair project will be a Rohde & Schwarz FSEA 20/30.
I will receive it within the next weeks, presumbably, and it has a known fault:
STEST aborted: RF-Modul RF-Converter, state 18
(see attached picture)
It is a device from a friend and he got it like this amongst other stuff. If I can repair it, that would be awesome, if not, no loss anyway.
My plan, once I receive the device, is:
1) Test it, get to know the installed options and firmware.
2) Clean it externally
3) Clean it internally: disassembling it, cleaning all contacts, re-assembling it
I hope/wish that step 3 could actually lead to a positive result and the device starts working again.
If not, what are my options? The RF Module is probably the most complicated component and I have not seen any replacement parts on eBay.
What are your suggestions?
Regards,
Vitor
PS: Also posted here - https://www.eevblog.com/forum/testgear/rohde-schwarz-fsae-30/msg1335536/#msg1335536
« Last Edit: October 29, 2017, 03:56:42 pm by Bicurico »
Offline Kilo Tango
Re: Repair: Rohde & Schwarz FSEA 20/30
« Reply #1 on: October 29, 2017, 08:23:10 pm »
Best of luck with the analyser. It might be a bit more involved than just clean contacts but you might be lucky.
The service manual is available on ko4bb's website, it is not bad,there are a selection of self test functions that you can start that may help you.
Ken
