All,
I recently aquired a HP 1745A scope. It was working when I got it (at least to some degree) but now it will not power up. I'm a hack when it comes to these things (which is two notches below an amateur), so please bear with me on this. When I got it the unit fired up, two traces appeared, and for the most part it seemed that the major functions at least did something when I monkeyed with them. I was able to display both traces using the calibration signal. Then I connected microphones to the two channels and was showing my kids what sound looks like in wave form. It's been a long time since I've had my hands on a scope, so I was learning all over again as I went. At any rate, last night I got brave and dug out an old RCA WR-50B RF singal generator I have had kicking around. It took some time to get a decent signal. I don't know that the signal generator is in the best of shape. At any rate, I left the two connected and turned on. I went to do some other things and forgot about it. This morning I noticed that the signal generator was still on, but the scope was not. It seems something happened to the scope where it won't even power up. The power led doesn't illuminate. The main fuse checks good. I pulled the top cover off and didn't find anything obvious. The fuse inside on the high voltage side also checks good. I have not pulled the bottom cover off to see what I find there. I am hoping someone will have some ideas where to look first. I appreciate any help you guys can offer.
Thanks,
Aaron
