I think I have a bad LM338K on a vintage test equipment. The +5V rail goes only up to 4.7V using the adjustment Pot. I purchased a new LM338K from Jameco for $10 and it gives even lower output voltage. I found somewhere that the LM338K, when ADJ pin is connected to GND, it should give 1.25V (The Reference Voltage) in the output pin. When I do this test on the original LM338K that I suspect is bad, I get 1.75V. On the new regulator purchased from Jameco, it gives only 0.9V!!! Is this a valid test? Input voltage is 12V DC.
