Hello
Working on a device with a LM5176 converter, the output side capacitors need to be replaced.
The device has 4x capacitors in parallel on either side of the current shunt (8x total) (schematic screenshot attached)
The data sheet calls for 50uf on one side of the current shunt and 360uf on the other (typical schematic attached)
Ceramic capacitors at this rating are $10s of dollars each on the main suppliers @ 25V max rating. Output is 16V
The device will work in a buck/boost config as battery and external DC powered approx a couple of amps max
Are these expensive capacitors the best option?
