I have some small notebook-power-supply-like SMPS I want to use to charge 48V LiIon batteries.
These batteries have internal battery managment systems for safety.
I need a voltage of 13*4.2V=54.6V and limited current of about 1A (constant current mode).
I know how to change output voltage of SMTP (by changing a voltage divider in feedback loop) to fit the 54.6V I need.
But:
When I connect the power supply to battery, current is about 2A for about a second, then power supply switches off (because 2A is over spec.).
I need to add some circuit, that limit output current to about 1A.
Can someone show me a circuit diagram of a current limiting (constant current) SMPS?
I think LED light power supplies may be suitable, but I don't want to buy new power supplies, I just want to use these ones I already have.
The additional circuit maybe a shunt resistor, OP amp, reference Z diode,... something similar this way, that controlls the opto coupler in feedback loop of SMPS.
Could this work?
![](https://www.eevblog.com/forum/repair/how-to-limit-output-current-on-switch-mode-power-supply/?action=dlattach;attach=264672;image)
