Author Topic: how to flash rigol via jtag?  (Read 930 times)
Offline ivi_yakTopic starter
« on: December 21, 2017, 11:27:54 pm »
how to flash rigol via jtag? help  |O
eevblog
Offline denimdragon
  • "Hole charge chaser and wanna-be o-scope fixer"
Re: how to flash rigol via jtag?
« Reply #1 on: December 22, 2017, 12:05:34 am »
Did you figure it out?
"Hi there. I'm short in the hair department, do you mind if I pull a few strands from your head? Thanks!"
The following users thanked this post: ivi_yak
« Reply #2 on: December 22, 2017, 11:53:07 pm »
thanks for reply!
not yet its impossible in real life, theoretically seems the only one way to restore
1) find same oscill
2) make 2 damps of memory
3) ds1302ca does not have flash sockets you need to assembly it manually
3) flash your brick
rigol support don't want to support their old models
eevblog
