Author Topic: How does laptop lid position sensing work?  (Read 4685 times)
Offline max.wwwangTopic starter
« on: March 29, 2020, 07:16:18 am »
I use an external monitor with my laptop without its own screen (lid closed). Every time to turn it on I have to lift the lid, press the power switch and close it. I found it a hassle so wanted to have an external power button (quite often I have other stuff on it, e.g. another laptop. Actually, I wanted it to disappear from the desktop to save space. I can put it below the desktop and leave only the power switch somewhere as its human interface). I did this today - external leads work well but only limited to powering on the machine - it does not complete the boot process (only if I lift the lid again). I changed the power setting in Control Panel (setting it to "do nothing" if closing the lid).
Seems like I have to hack the lid sensing mechanism to have it work the way I want. I Googled but found no answer on how the lid position sensing works for this model or similar. It's a Lenovo E560.
Some webpages suggest magnetic sensing for some models.
« Last Edit: March 29, 2020, 07:31:57 am by max.wwwang »
Neutral | grounded
Offline PTR_1275
Re: How does laptop lid position sensing work?
« Reply #1 on: March 29, 2020, 09:04:32 am »
Get some magnetic viewing film from ebay and run it round the edge of the screen to find the magnet
Or run a magnet around the edge of the computer and see where it is when the laptop goes to sleep. You’ll find some sort of sensor on the board in that position. Never looked at what type is used, maybe a hall sensor, maybe a standard reed switch
Offline mikerj
Re: How does laptop lid position sensingswork?
« Reply #2 on: March 29, 2020, 09:15:19 am »
Most always it's a magnet in the lid and a hall sensor in the base on modern stuff (used to be mechanical switches), removing the bezel from the display would confirm this.  Sensor likely mounted on the top part of the base that you haven't shown.
Note that the fan air intake is on the top, make sure there is sufficient airflow with the screen closed or it will be overheating/throttling.
« Last Edit: March 29, 2020, 09:18:52 am by mikerj »
Offline JKKDev
  • Country: si
« Reply #3 on: March 29, 2020, 09:56:43 am »
Here's a thought. Remove the screen assembly altogether. I think the only other thing in the screen assembly apart from screen and camera are the bluetooth antennas. If you don't need BT you're golden.
No overheating, no lid problem, lower power consumption :)
« Reply #4 on: March 30, 2020, 09:17:01 am »
This is an option but a bit too radical to me for now.  :D  First I may need the screen occasionally. Second, I still want to have BT although its ALMOST useless - I've been struggling to get it connected with my Bose Soundlink (headset) but never with a success (the same with my Toshiba)!
Thanks.
Neutral | grounded
« Reply #5 on: March 30, 2020, 09:19:34 am »
Thanks. Anyway, I have to reopen the whole thing another time. It's a bit hassle but it's now much easier (and I'm more confident) than the first time tearing it apart.
Perhaps I can find a reed switch or a hall sensor to detect where the magnet is.
Neutral | grounded
« Reply #6 on: March 30, 2020, 09:21:08 am »
Yes, using a magnet I may be able to locate the sensor (if it rely on a magnet). Thanks.
Neutral | grounded
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #7 on: March 30, 2020, 02:39:38 pm »
Never seen anything on laptops besides Hall sensors, most likely the sensor is near the power button, in that auxiliar board and the magnet will be in that zone of the bezel, in fact U1 to the right of the power button seems like the hall sensor, turn the laptop on with the display open and get a magnet near U1 and if the display disables itself thats the sensor.
The WiFi antennas are also on the display/lid.
Also, your fan is a bit dusty, your heatsink might be in need of a cleanup and a repaste.
« Last Edit: March 30, 2020, 02:42:48 pm by senso »
« Reply #8 on: March 31, 2020, 02:05:34 am »
Thanks. That gives me more certainty. I had a clean of the fan after seeing it dusty (though not thorough).
Neutral | grounded
Offline TonyBe
« Reply #9 on: March 31, 2020, 07:50:45 am »
without ever opened it: in case of my Lenovo T580, there it a magnet near the touchpad. When i hold a metallic pen close up, it holds on to it. Therefore i really think, that the sensing is made through a hall sensor in the lid itself (most likely near the Webcam). That also makes sense, since the sensor should only react if the lid is closed all the way down. Placing the sensor as far away from the hinge as possible is the easiest way to do this properly (without having to match tight tolerances and complex elektronics with comparators and stuff like that). :)
Regards
Tony
« Reply #10 on: April 01, 2020, 04:29:49 am »
Regards
Tony
Makes good sense. Why I'm seeking advice here is because of I want to get as much knowledge/certainty as possible before I even open it again. Thanks.
Neutral | grounded
« Reply #11 on: April 01, 2020, 07:42:32 am »
@ Blueskull is right. There is a small strong magnet in the bezel opposite U1 on the daughter board next to the power switch.
What's strange is -- having removed the magnet, it still refuses to start unless lifting the lid!
Neutral | grounded
Offline JKKDev
  • Country: si
« Reply #12 on: April 01, 2020, 02:43:36 pm »
If the screen still won't turn on after removing the magnet then there has to be another way that the laptop knows of the screen position. Try holding the whole laptop in the orientation that the screen would normally be in (this would point to an IMU in the screen, which could be used to detect the screens orientation - never heard of this approach but the idea came to mind :))
In regards to the hall sensor:
I've just gone over testing some hall sensors on HP laptops. What you are looking for is a SOT-23 package chip that has the single pin on ground and the two other pins should have 3.3V when the lid is open (even when the laptop is off, no battery, just the charger connected - this is in the HP case). If you put a magnet near the package one pin should stay at 3.3V while the other one drops to 0.
If you want to you could replace the reed switch with a normal switch between the two pins that aren't on ground and this way you can turn the screen on and off whenever you want.
