That all sounds correct, the light is supposedly 60w and the max current tested on the datasheet is 4.5a.
Just a bit of a noob question, but how does the current sensing drop to 250mv? I thought the drain would be connected to the source once the MOSFET was turned on, causing that area of the board to be around 10v? Or does the coil drop that?
