Author Topic: how do I cap a pair of short electrical wires ?  (Read 1446 times)
Offline HextejasTopic starter
« on: May 18, 2020, 04:41:40 pm »
This connector had 4 wires coming from it and I only needed 2 so I cut the other 2 off. Now I got the potential for a nasty shock unless I can figure out a way to cap them off. The 1st thing that came to mind was a small wire nut but maybe there is a better way.
Any ideas ?
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
Re: how do I cap a pair of short electrical wires ?
« Reply #1 on: May 18, 2020, 04:54:49 pm »
 . Hot glue works well. and has a high insulation factor. not so pretty .
Can rape some tap round first an then inject the hot glue in when cold remove the tape
 and you should get a nice molded finish .
or if you require something a little stronger epoxy resin ( Not the Metal epoxy)
Use scotch tape makes a good molding frame.
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
The following users thanked this post: Hextejas
Offline propman
« Reply #2 on: May 18, 2020, 05:03:13 pm »
Heatshrink
The following users thanked this post: Ian.M, Hextejas
« Reply #3 on: May 18, 2020, 08:30:37 pm »
Thats a really good idea, thanks. I might just combine it with the heat shrink and see how it turns out.
« Reply #4 on: May 18, 2020, 08:31:22 pm »
Offline telectric
« Reply #5 on: May 18, 2020, 09:00:22 pm »
Make the heat shrink a quarter inch (6mm) or so longer and while it is still warm pinch together the extra length with a pair of pliers.  The two sides will stick together and make a seal.  If you use heat shrink with an internal adhesive it will not come of easily either.
Tracy
Online Gregg
« Reply #6 on: May 18, 2020, 10:45:30 pm »
Pop the connectors out of the housing one at a time and trim the stubby wires as close as possible with flush cutters.  You may have to straighten out the locking prong on the crimp connector to get it to click in place properly.
Offline tkamiya
« Reply #7 on: May 22, 2020, 05:36:53 am »
I typically leave wires little longer and heat shrink it.
Can you remove the pin?  Then you really don't have to worry about them.
