Author Topic: MATSUSHITA PANASONIC AM4100 MICRO SWITCH  (Read 1047 times)
Offline asteroneTopic starter
« on: March 10, 2021, 10:06:36 pm »
Hi, I'm repairing a Sanyo stereo unit and it seems 2 of the micro switches have failed so I'm looking for some technical details and replacements for them, MATSUSHITA PANASONIC AM41008 MICRO SWITCH.
Ive done a search online but it seems these are outdated and little info is available let alone exact replacements. As these have specific screw holes in the stereo chassis, direct replacements would have been preferred, so perhaps any suitable micro switch suggestions and then I could probably 3D print an adapter of sorts.
Offline perieanuo
Re: MATSUSHITA PANASONIC AM4100 MICRO SWITCH
« Reply #1 on: March 11, 2021, 06:50:36 am »
hi,
if you don't find easily those switches on farnell or so, adapting standard microswitches should be a walk in the park
« Reply #2 on: March 11, 2021, 09:35:53 pm »
Yep, more than likely what i will do, i was hoping though that someone would be able to provide some technical specs on that micro switch so i could find a very close match. Seems i will need a low force acuation switch.
