I have a Kohler 6 KW AC generator on my boat that now shuts down immediately after startup with an over voltage error code. The voltage regulator consists of a printed circuit board driving a full wave SCR/diode Bridge, driving the generator field.
The SCR/diode bridge passes all of the ohm meter tests with the possible anomaly of the gate to cathode resistance on one SCR is 3 ohms and the other is 30 ohms. Using an external 9 volt battery and bulb both SCR’s block and then fire with a gate signal.
I reconnected the bridge to the generator, but left both gate leads off. I fired up the generator and still got an over voltage shut down. I then removed one AC input lead from the bridge and got an under-voltage trip upon startup.
This leads me to believe that one(or both) SCR’s are self triggering causing over excitation of the field and the over-voltage shutdown, though they seemed okay with the low voltage DC test.
Since the bridge itself costs about $60. I thought I would get a second opinion from The Forum before proceeding.
Thanks,
Tom
