I know most of the Dell 2800 series and earlier servers used the 68 pin cables internally but they will probably be M/M, but if you can use one of these instead of the installed cable plus extender it may be a solution and I would expect you could pick one up fairly cheaply on the used market.
However the 100 pin is more of a problem.
