Author Topic: Hioki 3283 Clamp meter repair help request  (Read 518 times)
Offline ntj77Topic starter
  • Country: in
« on: November 13, 2020, 02:19:14 pm »
Hi, I purchased a used non working Hioki 3283 Clamp meter and trying to repair it. Now it is switching ON and measurements are possible except for the "FILTER" option, which is low pass filter especially for measuring VFD. There is no signal at all if I enable "FILTER" key, reading is 0.00.
Can someone please help with a schematic of the filter circuit or at least where to look on the PCB?
Offline bob91343
Re: Hioki 3283 Clamp meter repair help request
« Reply #1 on: November 13, 2020, 07:36:16 pm »
Did you contact the company?  They will probably tell you to send it in but it's worth a try.
