Author Topic: Hercules 20v Battery - Pinout?  (Read 1225 times)
Offline AmmoJammoTopic starter
« on: June 23, 2024, 03:47:41 am »
I'm trying to power a Hercules impact driver from a different battery.
I do not have access to a Hercules battery.
The tool has 4 contacts, two for power, and another two unknown terminals.
Without the two other terminals connected, the tool refuses to run.
Does anyone know what these terminals are for? Or have a battery they can try to identify their function from?
Thanks!
Offline Phil1977
Re: Hercules 20v Battery - Pinout?
« Reply #1 on: June 23, 2024, 11:22:21 am »
In case no one has a functioning model of this battery:
Quite often (e.g. at Makita & Dremel) the battery has a "Power good"-output telling the motor driver that everything's okay. If you connect the power-contacts to your lab supply, you could try to connecting e.g. a 1kOhm-resistor between (+) and the two unknown terminals. From my gut feeling chances are low you destroy something but chances are there that you activate the motor.
Offline soldar
« Reply #2 on: June 23, 2024, 12:04:36 pm »
I think it may be a temperature sensor, just a temperature dependent resistor. I would try putting a resistor. First between the two free terminals and if that doesn't work then between each terminal and the negative of the battery.
Think one would have a temperature dependent resistor to negative and the other might be for data  or battery capacity identification.
« Last Edit: June 23, 2024, 12:13:05 pm by soldar »
Offline fzabkar
« Reply #3 on: June 23, 2024, 06:22:34 pm »
I would at least start by measuring the voltage at those two pins after connecting just the battery terminals. If one terminal is sitting at 5V, say, then that could be the top end of a regulated potential divider. This would be consistent with a temperature sensor. The bottom end would be grounded, either directly or through a resistor.
« Reply #4 on: June 24, 2024, 10:32:00 am »
One pin goes to 5v when the trigger is pulled, and stays there once its released for about 2 seconds.
There also looks to be a 1.5ms 0v pulse while this pin is held high.
The other pin doesn't seem to measure anything.
« Reply #5 on: June 25, 2024, 10:33:45 am »
10k pull down on the 5v pin drops it to 3.3volts.
But it still doesn't power up.
Nor does grounding the other pin at the same time.
Offline Phil1977
« Reply #6 on: June 25, 2024, 12:16:08 pm »
You could buy an adapter like this:
https://www.ebay.com/itm/204832576543
It seems to have two input and three output pins. So it knows the secret how to activate the Hercules tool.
Maybe there is more info somewhere how these adapters work.
Offline tunk
  • Country: no
« Reply #7 on: June 25, 2024, 12:54:41 pm »
Where do the two contacts go? Maybe you could post a photo of the PCB,
and if the contacts go there, maybe you could mark where they go?
Offline fzabkar
« Reply #8 on: June 25, 2024, 04:42:52 pm »
There must be a 5.1K series resistor. Perhaps you could try 4K7 or less?
« Reply #9 on: June 28, 2024, 07:56:11 am »
I haven't found one to use different batteries in the Hercules tool, and someone else did, but it didn't work in all tools.
It's potted.
4k7 pulls it down to ~2.4volts, but it still doesn't do anything.
I suspect the other pin, or even this pin, is being used for data..
Offline fzabkar
« Reply #10 on: June 28, 2024, 11:24:10 pm »
If that pin was a data line, and if the signal was open-collector, one could expect that the 5.1K pullup resistor would be on the receiving end. Therefore, I'm thinking that the battery is sending something to the "controller" via this pin, assuming it's not a simple thermistor.
« Reply #11 on: July 02, 2024, 10:20:19 am »
The Ozito tools use the NTC pin for data, when the battery is on the charger...
I bought an adapter to use Ozito batteries on Milwaukee tools, and this adapter pulls one of the extra pins to the battery 0v through a 10k resistor, and the other to the battery voltage through a 10k resistor...
Not something I'm going to try on the Hercules!
« Reply #12 on: July 04, 2024, 09:20:23 am »
It seems like Hercules changed the way the newer tools talk to the batteries, so the adapters stopped working, and hence were pulled from sale:
https://youtu.be/sdfGr3GHHMw?si=oFpk1HBI6HtltpgD
