Ok so i went ahead and started the ADC troubleshooting. I set up the meter as per the instructions, removing the interconnect to the out-guard board, disconnecting the analog jumper, and feeding in -10vDCc to the input terminals.
I am only getting one waveform coming out of the ADC board, so I followed the troubleshooting guide further. I am not getting -10v at A10TP4, there is just 0.3v sitting there.
I found out the front/rear input switch had the HI contact bent and not making contact. I bent it back and now I have -10v on the input to the first resistor. Something is loading down the multiplexer node after A10Q1. A10Q1 is being turned on by the comparator, which is receiving 5v on pin 7 (+ input) of A10U8. The theory of operation says that no attenuation should be active from 0.1v-10v, and that it is directly connected to the input of the DC preamplifier. Q2 has its gate pulled low, so it should be off. Perhaps there is a shorted FET somewhere, or another comparator is shot.
I think we're on the right track, and that the problem might be in the input amplifier.
Also, yes, the ohms converter is switched on by a latch controlled by the in-guard processor. The divide-by-4 that supplies the switching to the DC-DC converter has the CLEAR pin tied to a latch.
Let me know what you think.
