Author Topic: Flex flat jumper cable, what options?  (Read 986 times)
Offline peteb2Topic starter
« on: November 12, 2023, 09:40:07 pm »
So i have some operator panels that are mission critical that need the rotary encoders changed in. That's easy but there are multiple very basic 10 way, 0.5mm pitch 5.5mm width x 78mm long that feed various switch arrays or displays sections & these are now due to age de-laminating & cannot be reinstalled.
It's impossible to hard wire, the manufacturer has classed the equipment as No Longer Serviceable (so no spares).
These were made by Sumitomo who provide a very comprehensive pdf catalog on such tech.  I have searched & find various suppliers DigiKey, Mouser etc that do not carry stock. They can contract to manufacture but that means many, many units!
What to do? My only option as i see it is whether anyone may have seen such a flat ribbon flex used elsewhere & in another product? Length is not important. Perhaps it is a current spare part? This is the 1st time such a situation has arisen so things are kind of desperate! Has anyone else had this sort of problem?
Online factory
Re: Flex flat jumper cable, what options?
« Reply #2 on: November 12, 2023, 10:22:52 pm »
Look on Mouser or elsewhere for FFC or FPC jumper cables, they have loads from various brands in 0.5mm pitch, just need to choose length & check the connection end thickness with the datasheets.
Online Ian.M
« Reply #3 on: November 12, 2023, 10:49:12 pm »
Try Farnell - they stock 3" and 4" 10 way 0.5mm pitch flat flex cables.
« Reply #4 on: November 13, 2023, 12:54:40 am »
Have done that & they always come to a 'will be manufactured' message & a somewhat delay to delivery!
Offline t1d
« Reply #5 on: November 16, 2023, 01:46:35 am »
The Asian PCB manufacturers are now making flexible PCBs. I have seen lots of DIYers designing custom cables and having them manufactured on flexible PCBs. Some of them can manufacture things overnight. Also, how about just good old Dupont cable? I guess it all depends on the needed current. HTH.
Offline chubbymonk
« Reply #6 on: November 19, 2023, 02:36:50 am »
In my experience, I’ve found that LCSC have quite a large stock of FFC’s.
https://www.lcsc.com/mobile/products/FFC-Connectors_920.html
From a quick search, this one seems to fit your needs? You’ll have to measure the thickness of the cable as well on the mating ends.
https://www.lcsc.com/mobile/product-detail/FFC-FPC-Connect-Cables_JUSHUO-JS05A-10P-100-4-8_C2857479.html
I’ve used the JUSHUO brand before and they seem to be of ok quality.
Offline kleiner Rainer
  • Rainer DG1SMD JN48ts
« Reply #7 on: November 19, 2023, 12:49:06 pm »
I got samples from Würth in Germany. They have many standard FFC types ex stock, here 10-pole 0.5mm pitch, length 100mm:
https://www.we-online.com/components/products/datasheet/687610100002.pdf
Mouser has them in stock, minimum quantity 1:
https://www.mouser.de/ProductDetail/Wurth-Elektronik/687610100002?qs=PhR8RmCirEZB4c0lS6qCVQ%3D%3D
Greetings,
Rainer DG1SMD
