I have had my Logitech Z-2300 speakers, which I quite like, for around 15 years. I keep them on all the time. Unfortunately over the past several years they have increasingly developed a hum, which I am finding intolerable.
I contacted several repair shops and they won't take a look as they claim they can't get replacement parts, and instead suggest buying new. I see no reason for that and I would like to repair and keep using them if reasonably possible.
The facts:
- The hum/buzz is present without any signal input connected. (3.5mm jack disconnected)
- The hum comes mostly from the torroidal transformer in the subwoofer cabinet, (which also contains the electronics).
- The hum persist even if the speaker wires to the subwoofer and the satellite speakers are disconnected, i.e. it's really mostly from the transformer.
- There is a bit of the same hum coming from the speakers, but very little.
- The hum seems to be 120 Hz based on comparison to test tone clips on youtube.
- The two large 10000 uF capacitors, which are typically recommended to be replaced in the presence of such symptoms, measure at their rated capacitance by my DMM.
- None of the capacitors appear damaged to my eyes, though I did not test the others.
- The AC power plug for this speaker system has only two prongs.
- I tried plugging into different outlets: a UPS, surge protector, different outlets. The result is always the same.
In case it might help, this link has some information about the electronics of these speakers:
https://www.electro-tech-online.com/threads/help-required-on-logitech-z-2300-toroidal-transformer.114427/page-6#post-941333I'm not overly familiar with debugging electronics, but I have disassembled the board (so much glue!) and I have a DMM and soldering iron.
Here is my previous "work" on these speakers:
https://www.avsforum.com/forum/89-speakers/3088462-diagnose-repair-buzz-hum-logitech-z2300-subwoofer.html I tried replacing the 10000 uF capacitors anyway, and not only did that not make any difference, but I lost the copper sleeving in the through-holes on the PCB and had to use wire to connect the two sides of the holes. Now I'm back to the original problem. Hopefully no more detours.
Any recommended steps to diagnose and hopefully fix this hum would be most appreciated! It's driving me crazy.
