Solved. OMAX microscope good again! -And working without trouble on 12v!
Disclaimer:
This repair saved me, but will almost certainly invalidate your warranty. If you fried your PCB, it is probably not covered anyway, so what are you going to do?Yes, I too got the booby prize for plugging in 12v and fried the PCB, the LED and the potentiometer! Couldn't find a replacement DXL80D so decided that this is a simple LED dimmer project, and started over, using LM317T, a cheap part detailed at
https://circuitdigest.com/calculators/lm317-resistor-voltage-calculator and available from
https://www.amazon.com/gp/product/B07VNNHWF9/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 . Details that might be useful: R1 470R, R2 the dimmer control (replaced with 4.7k 3W)
https://www.amazon.com/gp/product/B017LBAWIA/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1 . This control is heaver, but fits with a little reaming out of its mounting hole; the 4mm shaft rits the original wheel knob. I bridged a 1k multiturn between the two blue wires on the dimmer to calibrate the LM317T output voltage to the LED forward voltage spec. Anything else? Not really but a heat sink is advised for the LM317T
https://www.amazon.com/gp/product/B081GRZB6S/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1 . The silicone mat and insulator were omitted.
Ah yes, I blew the LED too!
Replaced with same spec 3W LED
https://www.amazon.com/gp/product/B01DBZICDC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&th=1 applied with silicone cooler paste to heat sink
https://www.amazon.com/gp/product/B06XKTRSP7/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1 .
Calibration: (important) Turn the dimmer to minimum before applying power. Measure voltage at LED+ and LED- slowly increase the dimmer , adjusting the 1k preset to keep the voltage 2.8 - 3.0v. Eventually the dimmer will be at maximum, time to adjust the preset to exactly 3.0volts, the specified forward voltage for this LED.
Tidy it all up and enjoy, safe in the knowledge that everything that can be broken, fried or just die is now replaceable quickly and easily.
Yes, I know this is a cheap and dirty solution to the problem but it does restore full functionality and it's an inexpensive repair to the fine microscope.
I suspect that this simple LM317 "hack" might be a prctical starting point for any other LED dimmer projects?
(If we wanted to be "respectable" we wouldn't use variable voltage, we'd use a constant current source and PWM dimmer for much more moolah and complexity. This li'l LM317 is robust and easy and works.)
![Help with an Omax PCB/Driver?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=242066.0;attach=1336835;image)
the repair with LM317T
![Help with an Omax PCB/Driver?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=242066.0;attach=1336841;image)
The LM317 dimmer board. That's all there is to it!
![Help with an Omax PCB/Driver?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=242066.0;attach=1336847;image)
The dimmer potentiometer bridged with calibration multiturn preset.
![Help with an Omax PCB/Driver?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=242066.0;attach=1336853;image)
Fried original PCB. Good riddance! The microscope is better now than before.
