Author Topic: mastech DC POWER SUPPLY  (Read 613 times)
Offline westerjimmy495Topic starter
« on: September 04, 2021, 10:44:31 pm »
The current display stopped working still has the current just no display anyone ever seen this have not removed cover yet getting idea's on what to check any suggestions ...Thanks  [/img]
Offline bob91343
Re: mastech DC POWER SUPPLY
« Reply #1 on: September 04, 2021, 10:55:35 pm »
I never looked at those displays but you can see if there is a poor connection.  Otherwise you may have to replace the display, depending on what's wrong.
Pull the cover and probe around looking for loose connections.
The following users thanked this post: westerjimmy495
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: September 04, 2021, 11:49:10 pm »
The displays on those Mastech power supplies are usually 7106- based DMMs totally independent of their main board, so it becomes almost a replaceable part entirely.
For it to die completely, I would suspect power supply to the ammeter (a broken wire, perhaps?) or a complete breakdown of the 7106 (much rarer occurrence IMO).
