I think the code is F2=. The leading marking appears to be a vertical line.http://markingcodes.com/search/c/f2%3D
Quote from: fzabkar on November 13, 2023, 04:12:49 pmI think the code is F2=. The leading marking appears to be a vertical line.http://markingcodes.com/search/c/f2%3DIt's a vertical bar but it's actually a part of a part number marking, and R7732LGE actually has |F2=marking which is a bit unusual for Richtek as in 99% of cases their ICs have 3 or 2 symbol marking. F2= that website shows for it is incorrect. Neither Richtek puts vertical lines on their ICs to mark orientation, they put a small triangle in the corner of pin 1.
