Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
beginner try to repair old HP 54720A scope
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: beginner try to repair old HP 54720A scope (Read 3829 times)
Daxxin
Regular Contributor
on:
April 05, 2017, 07:48:29 pm »
looks like something wrong while OS firmware loading ..it hangs try to view
this short video
https://youtu.be/dC2fFuHED0E
any hal or experience
very apreciated
Logged
tpowell1830
Frequent Contributor
Country:
Peacefully retired from industry, active in life
Re: beginner try to repair old HP 54720A scope
Reply #1 on:
April 05, 2017, 08:30:07 pm »
Do you have the service manual?
If not, here is the link:
http://dedisol.unsads.com/~squalyl/kurteries/manuals/HP%20Agilent/HP%2054710A,%2020A,%2017A,%2018A%20Service.pdf
1. Did you try to reseat the boards as suggested on page 5-22?
2. Do you have the original floppy with the firmware? If so, then you may need to reload it as per page 5-15.
I hope this helps. Good luck.
Logged
PEACE===>T
Daxxin
Regular Contributor
Reply #2 on:
April 06, 2017, 04:09:28 am »
thanks Tpowell im taking apart soon , about system disks ..nothing even googoling never found
if someone has please share them.
Logged
Daxxin
Regular Contributor
Reply #3 on:
April 16, 2017, 10:24:37 am »
Battery totally discharged 0v , i have only 3.6 lithium same size to solder its ok to replace with this? Original its cr17450se 3V
Logged
Daxxin
Regular Contributor
Reply #4 on:
April 16, 2017, 03:28:07 pm »
Replacing the battery back to alive but calibration of mainframe gone need specific module 54717A
to calibrate it.
Logged
sahko123
Country:
Reply #5 on:
April 16, 2017, 06:44:33 pm »
Whats the blue mod wire for?
Logged
Asking for a friend
Cyberdragon
Super Contributor
Country:
Reply #6 on:
April 16, 2017, 09:49:24 pm »
Quote from: sahko123 on April 16, 2017, 06:44:33 pm
They probably needed to connect those pins but had a perpendicular track across there on every layer. #autorouted
Logged
*BZZZZZZAAAAAP*
Voltamort strikes again!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
