Author Topic: Help Source Output Power Module  (Read 314 times)
Offline GeworthomdTopic starter
« on: January 16, 2024, 07:14:10 pm »
:-// :-//][url] :-// :-//[/url]
Gentlemen,
May I ask for your help. I trying to source these for a project on an older piece of audio that is being repaired for me but not by me. I don’t know much. If your questions are technical I will have to back and ask first so please be a bit patient with my limited knowledge. This isn’t my profession. If you can help then I would respectfully appreciate it.
Offline Swake
Re: Help Source Output Power Module
« Reply #1 on: January 18, 2024, 12:56:08 pm »
It is not mentioned what electronic component exactly you are sourcing. From your text is seems that you are looking something that has to do with a power supply with 3 output channels. Given the 500 Volt DC for the first channel I suspect this is about an audio device with tubes.
If this is indeed about a repair, there should be a power supply already in the device. It should be possible to repair that power supply. And this is likely also the easy route.
Sourcing a power supply with the listed requirements is not that difficult, although one with an appropriate 500 V channel might be a bit more difficult to find as not very common these days.
Could you confirm a power supply with the 3 specified channels is what you need? Or 3 separate power supplies which is the same. Can the two 9 to 11 Volt channels be combined or is a galvanic isolation required?
This said, the person dealing with the repair should be able to source the power supply too as there is nothing voodoo about that.
When it fits stop using the hammer
