Author Topic: SOT353 SMD identification  (Read 813 times)
Offline TheMGTopic starter
« on: October 25, 2020, 04:55:48 pm »
I'm trying to identify these components but I'm coming up empty.
All 3 are SOT353 package, and on all 3 of them pin 5 is VCC (3.3V) and pin 3 is GND.
These are in a part of the circuit associated with RS232 and RS422/485 line drivers/receivers. On the properly working channels, all pins read either 0V or 3.3V. So my best guess is they are some sort of logic gates or something, possibly something to do with switching between RS232 and RS422/485 depending on configuration I would assume.
I'm hoping to avoid having to resort to de-soldering known working ones and doing trial-and-error to figure out what type of gates they are. Anyone able to identify these?
Offline fzabkar
Re: SOT353 SMD identification
« Reply #1 on: October 25, 2020, 06:08:06 pm »
SN74AHC1G86DCKT, Texas Instruments, Single 2-Input Exclusive-OR Gate, 2 V to 5.5 Vin, marking AHG, SOT-23-5:
https://www.ti.com/lit/gpn/sn74ahc1g86
Could the S08D component be a "single 2-Input AND Gate", eg MC74HC1G08, 74V1G08 ?
https://www.onsemi.com/pub/Collateral/MC74HC1G08-D.PDF
https://media.digikey.com/pdf/Data%20Sheets/ST%20Microelectronics%20PDFS/74V1G08.pdf
... and could S00B be a "single 2-Input NAND Gate", eg MC74HC1G00, 74LVC1G00?
https://www.onsemi.com/pub/Collateral/MC74HC1G00-D.PDF
https://assets.nexperia.com/documents/data-sheet/74LVC1G00.pdf
Edit:
NC7S00P5X, On Semi, TinyLogic HS 2-Input NAND Gate, marking S00, SC-88A:
https://www.onsemi.com/pub/Collateral/NC7S00-D.PDF
NC7S08, On Semi, TinyLogic HS 2-Input AND Gate, marking S08, SC-88A:
https://www.onsemi.com/pub/Collateral/NC7S08-D.PDF
« Last Edit: October 26, 2020, 12:09:35 am by fzabkar »
The following users thanked this post: TheMG
« Reply #2 on: October 27, 2020, 12:09:38 am »
Wow! Awesome. I guess what caused my searches to return nothing I incorrectly assumed that the "B" in S00B and S08B was also part of the part code/marking.
What I measure steady-state on each of these parts in the working channels does fit the truth table for each one, so I'm fairly certain you have correctly identified them.
Now to order the replacement ICs and see if I can get this fried channel (transient/lightning damage) working again.
Thanks!
