Author Topic: Help repairing old Heathkit RF signal generator IG-102  (Read 8592 times)
Offline heathkitmanTopic starter
« on: December 30, 2014, 01:04:27 am »
Hi , I'm looking for some guidance to try to get my old Heathkit RF signal generator IG-102 back up and running for nostalgic reasons. It was in storage for about 30 to 35 years. I replaced a few of the caps, as needed, and the tubes. The test voltages are now correct and unit is basically working but I have the following two issues.
The AF output is 340 Hz instead of the specified 400Hz.
The main problem is there's very little amplitude to the RF output.  You have to have the attenuation turned up to maximum output to be able to detect any signal at the RF output BNC.
Any help would be greatly appreciated.
http://www.heathkit.nu/IG-102_schematic_1600.png
Thanks
heathkitman
« Last Edit: December 30, 2014, 01:12:07 am by heathkitman »
Offline N2IXK
Re: Help repairing old Heathkit RF signal generator IG-102
« Reply #1 on: December 30, 2014, 01:18:42 am »
The 400Hz was only a "nominal" frequency.  Check the cap values (C13-C16) around T2 to see if they are within tolerance. Check all the carbon comp resistors in the unit for drift, as well.
Do you know if the unit ever worked properly? Assembly errors are MUCH more likely when dealing with kit assembled units.
"My favorite programming language is...SOLDER!"--Robert A. Pease
« Reply #2 on: December 30, 2014, 01:23:11 am »
The unit was functioning properly when it was put into storage many years ago. It was assembled by one of the technicians that maintain the equipment at the USNA lab for 30 years.
Offline xwarp
« Reply #3 on: January 01, 2015, 10:48:37 am »
Here is something you may want to consider:
http://km5z.us/blog/?p=67
I plan on doing that with mine.
Offline Seekonk
« Reply #4 on: January 04, 2015, 06:01:16 am »
I have one of those I bought for a friends kid who lost interest in electronics before I could fix it up.  Mine was wired beautifully  but at the higher frequencies wouldn't oscillate.  Adding extra bypass caps and other tubes wouldn't fix it.  Set it aside for years since I have plenty of other generators.  I also thought about converting it to FET operation so I could use it at my camp which is only 12V.  That article is inspiring me.
Offline N2IXK
« Reply #5 on: January 04, 2015, 03:21:51 pm »
I worked on a similar vintage and quality unit (Eico, IIRC) which refused to oscillate on higher bands unless it was installed in the case. Made trimming the frequency rather frustrating...
Offline steve_w
« Reply #6 on: January 06, 2015, 05:06:37 am »
If it used to work, something has changed, if the voltages are good it looks mechanical.
Check the switches, give em a good clean and check continuity with a meter, it might throw something up.
regards
Steve W
So long and thanks for all the fish
Offline oldway
« Reply #7 on: January 06, 2015, 06:39:45 am »
Replace:
C17 : 0.01µF
C20 : 0.01µF
Test tubes if you can or replace them.
Check power supply for ripple.
« Last Edit: January 06, 2015, 06:45:25 am by oldway »
Offline Rory
« Reply #8 on: January 06, 2015, 07:03:25 am »
Concur with Oldway. Also check C22 and look for cold solder joints in the signal path.
Offline Cyberdragon
« Reply #9 on: January 06, 2015, 08:19:13 am »
Did you change the HVDC filter caps? Check the tubes but don't change them unless you know they're bad or else it could uncalibrate. They won't go bad unless it was abused.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline oldway
« Reply #10 on: January 06, 2015, 03:22:54 pm »
Don't worry about calibration !
Change the tubes to see if it solve the problem. If not, use the original tubes again.
This was a commun procedure with tube color TV sets, never had problem with this !
Calibration procedure is easy to do if necessary.
I have an old tube TV - FM Sweemar generator model LSG-532 LEADER and it is still working very well.
