Hi there, so I'm really gutted, but basically I purchased a bypass cable from ebay to allow you to bypass the control pod and use the system with a 3.5mm jack, however when trying it out it worked for a couple of minutes then suddenly stopped. I tried plugging back in the control pod and it works for a about 10 seconds then freezes displaying squares on the screen...
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
I'm not sure if this was the cable that caused this issue, or just a really timely coincidence, but somewhere in the subwoofer (which houses the amp) something is now broken...
So I have two questions, firstly is can anyone reassure me that this cable didn't cause the fault, because if it did I'm going to go
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
crazy to the ebay seller, what's the likelyhood here?
and secondly, where on earth would I begin trying to diagnose where the issue lies in the sub? I have taken the back off and inspected all the parts with no obvious signs of any issues
I love these speakers, so any help would be much appreciated
thanks
