Hello,
This NAD L76 receiver is overheating and restarting (temperature protect is triggering) after about 6 hours of constant work. The audio output is OK. Nobody repaired it before.
It's overheating because the fan is never turned on. Normally, I suppose, when the temperature is OK, the fan motor is not spinning, but if the temperature is rising, it should start the fan for cooling.
Firstly I checked why the fan motor is never turning on. I ckecked the fan motor with a multimeter and with a battery - the fan is good, it's spinning when I apply voltage. Input voltages +5V and +15V are present.
Then I checked who is controlling the fan motor. TH71 PTC thermistor and two transistors, Q755 and Q751. TH71 is showing 278 ohm in normal state at 20C room temperature. When I apply heat, the resistance is increasing to about 380 ohm. I don't know if this component is OK (can't find the datasheet). But even without this thermistor, I can't start the motor. The transistor Q755 don't want to open. I can't figure out why the voltage is dropping and not reaching the gate. All resistance values are OK.
Somebody can help? Maybe I'm doing something wrong...
