So got a simple one that came in yesterday:
A set of highly accurate scales from a semiconductors lab, measures down to 0.01g. It has a VFD 8-digit readout and the problem with it was the leading number after the decimal point was flicking between 0 and 8 and going a bit brighter when it does so, naturally we assumed that the pin on the driver chip that was controlling that segment was going a bit funny.
So we took out the driver board with the intention of just whipping out the IC and and swapping it with the one that was driving the other half of the display, and socketing them whilst we're at it. The IC's are COP470 - long since gone out of production we believe from searching the internet.
Dates on the IC's put it around 30 years old (1984-85).
We stuck it under the viewer first for a nosey and what we found seriously baffled us:
This we believe to be the offending pin (testing pending). It not tin whiskers, they are way too big. Its been used regularly in a clean room for the past 30 years - has anyone else seen anything like this?
