Author Topic: Part identification / LED Monitor repair help  (Read 999 times)
Offline sonjaTopic starter
« on: July 19, 2020, 04:03:42 pm »
Hi together,
does anyone know what part this BAO N10 ACE4506 is, maybe a transistor? I think it is an TO-252 package, but I couldn't figure out what it is.
It is located in the input area of an ACER LED Monitor. Input voltage is 19 V. The monitor only powers up if I warm up the area around this part and doing a power cycle.
The voltage between the lower left and lower right pin is around 2.4 V, but only under load.
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
Re: Part identification / LED Monitor repair help
« Reply #1 on: July 19, 2020, 07:49:48 pm »
C 505 looks like it need re soldering and not making good contact.
That is a custom mark over . Could be a voltage regulator .
Measure all the voltages not just the voltage drop .  The tag is to ground  or plus ?
is the small centre pin a direct connection to the tag ?
Voltage from Tag to pin 1 ?
voltage from Tag  to pin 3?
Some monitors have a safety device and this is properly a SCR
Also R603 look as the end has come off  ..
This looks like a heavy load I would check the other components first ie that c 505 looks like a real bad connection .
Photo of the complete power section would also help
« Last Edit: July 19, 2020, 07:57:42 pm by Labrat101 »
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline Twoflower
« Reply #2 on: July 19, 2020, 07:54:26 pm »
I would be more worried about the hole in D504. And probably D501 looks not good either.
Offline fzabkar
« Reply #3 on: July 19, 2020, 08:25:45 pm »
EMBA0N10CS, Excelliance MOS Corp, N-ch logic level enhancement mode MOSFET, 100V, 12A, 100mOhm, marking BA0 + N10, TO-251:
http://www.excelliancemos.com/download_prod_s.php?ds=314&file=2
The following users thanked this post: sonja
« Reply #4 on: July 22, 2020, 08:26:51 pm »
It seems that I haven’t enabled mail notifications...
Thanks for your superfast replies!
Wow, thanks! I wasn’t able to find it, even identifying the brand by comparing the logo on the IC wasn’t possible for me.
I unsoldered the two diodes, they seemed to be okay. I think they are intended to prevent polarity issues on the input.
Thanks for your suggestions, I will try to investigate further and report back.
Offline fzabkar
« Reply #5 on: July 22, 2020, 11:41:15 pm »
Offline Twoflower
« Reply #6 on: July 24, 2020, 05:18:58 pm »
Just for ma understanding. The diodes in the picture look badly damaged. Is this only an artefact in the picture or do at least one of them has a part of the housing missing? If that's the case I really wonder how they could survive that. :o
« Reply #7 on: July 24, 2020, 05:36:41 pm »
I used these search terms:
https://ipv4.google.com/search?q=filetype:pdf+BA0+N10
Okay lesson learned, I switched months ago to duckduckgo. I missed to use !g for deeper searching.
Nah, they are okay. That is the bad image quality due to reflection and zoom.
