Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Help identifying LCD
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help identifying LCD (Read 837 times)
Robski
Contributor
Country:
on:
July 07, 2020, 05:51:07 am »
It is monochrome LCD I need to replace but there's nothing about the model number or manufacturer. It has flat 15 pin connector. Back light is separate supply with ccfl tube. I posted some pictures. The machine model is SAC-F4S.
The closest one I can find is this one:
https://fsshijie.en.alibaba.com/product/60475361775-803277332/640x480_VGA_Monochrome_15_pin_9_4_inch_LCD_Display_LM64P839.html
But its over 100USD so I don't really want to risk that much in case it doesn't work.
http://imgur.com/gallery/99fRDb2
Last Edit: July 07, 2020, 05:53:04 am by Robski
Logged
ajp8868
Regular Contributor
Country:
Re: Help identifying LCD
Reply #1 on:
July 07, 2020, 08:24:11 am »
Bit of a longshot but these might have a screen with a model number on or even a spare screen.. Is this the same interface unit?
https://www.aesintl.com/equipment-services/manufacturer/elettromeccanica-carra/t1340b/
Logged
fzabkar
Super Contributor
Country:
Reply #2 on:
July 08, 2020, 01:49:23 am »
Here is the datasheet and pinout for the Sharp LM64P89 & LM64P839 panel:
https://elektrotanya.com/sharp_lm64p839_lcdpanel_datasheet.pdf/download.html
https://www.beyondinfinite.com/lcd/Library/Sharp/LM64P839.pdf
The 3 power pins appear to be in the right place.
Dimensions:
http://www.bitsavers.org/components/sharp/Sharp_LCD_Panels/LM64P89.pdf
WARNING
: See page 55 of the following manual:
http://support.elmark.com.pl/advantech/pdf/PCA-6153man.pdf
Pin #7 (VEE) is the "external power" pin. The voltage requirement is -20V for the LM64P89 panel.
LM64183P -17V
LM64P89 -20 V
Last Edit: July 08, 2020, 02:04:28 am by fzabkar
Logged
Robski
gorge441
Robski
Contributor
Country:
Reply #3 on:
July 23, 2020, 02:34:45 am »
Thanks for that I will go and check the voltages before buying anything.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
