Author Topic: Help Identifying component and distributor  (Read 2895 times)
Offline manuTopic starter
« on: May 17, 2019, 12:21:34 pm »
I have a bluetooth Sony portable speaker SRS-XB20 which cannot charge its 2-cell 7.2V Li-ion battery.
The culrpit is probably this chip marked ASV7EA. I think it should boosts (when working!) the 5V USB to 8.3V and charge the battery.
It's probably a Silergy chip, some kind of step-up or battery charger ic.
The ref I have a datasheet for is a SY21282 but some pins don't match with what is populated on the pcb.
Does somebody know what ref is corresponding to the ASVxxx marking?
« Last Edit: June 06, 2019, 11:57:40 pm by manu »
Re: Help Identifying component and distributor
« Reply #1 on: May 21, 2019, 06:45:56 am »
close up on the chip:
« Reply #2 on: May 24, 2019, 06:57:43 am »
It seems to be SY6982 but the marking doesn't fit (the pinout does).
If someone have access to the SY6982A, it would be nice.
Offline fzabkar
« Reply #4 on: June 07, 2019, 06:26:21 am »
thanks,
it seems the ASV is some kind of variant as pin 5 & 6 are grounded.
I tried a SY6982E (from LCSC) and it doesn't work (because pin 6 is Vin sense and obviously must not be grounded to work properly).
SY6982C could work because pin 6 is ILIM
Anyway, I continue searching... Thanks for your help.
Offline fzabkar
« Reply #5 on: June 09, 2019, 03:23:11 am »
« Reply #6 on: June 09, 2019, 01:13:53 pm »
Yes, unfortunately no datasheet available...
Offline moochinazz
« Reply #7 on: May 25, 2020, 06:19:10 am »
Hi, sorry for resurrecting an old thread. Has anyone managed to find the replacement for the chip mentioned in the first post?
Offline fzabkar
« Reply #8 on: May 25, 2020, 08:00:14 am »
This is all I managed to find:
http://web.archive.org/web/20180920172840/http://s.no4e.com:80/143/3d0d05ba2c9213a0/resource/7d56632628fb93ab31ccfecea7272397.pdf (2014, Q2, product list)
http://www.szyucan.com/upfile/IC-PDF/SY6982E.pdf (SY6982E)
https://datasheet.lcsc.com/szlcsc/1809191920_Silergy-Corp-SY6982EQDC_C108510.pdf (SY6982E)
http://forum.fonarevka.ru/attachment.php/attachmentid=189921&d=1498199051 (SY6982C)
SY6982A - Prog. Charge Current & Timer, Fault Mode Without Battery, Adaptive Input Current Limit, 4.1 / 4.2 / 4.3 / 4.35V Cell Voltage
SY6982C - Prog. Charge Current & Timer,Boost Mode Without Battery, Adaptive Input Current Limit, 4.2 / 4.35V Cell Voltage
SY6982C1 - Prog. Charge Current & Timer,Fault Mode Without Battery, Adaptive Input Current Limit, 4.1 / 4.25V Cell Voltage
Offline onceagain
  • Country: md
« Reply #9 on: December 03, 2020, 07:15:53 am »
Hey, SY6982C is now available to buy. Do you still have that faulty speaker?
« Reply #10 on: December 11, 2020, 11:03:56 pm »
Yes I still have it, where can I buy it?
« Reply #11 on: December 11, 2020, 11:07:52 pm »
For some reason, I am not notified anymore when someone posts on this thread...
« Last Edit: December 14, 2020, 12:47:14 am by manu »
