Author Topic: HELP Finding Rotary Encoder  (Read 4600 times)
Offline factory
Re: HELP Finding Rotary Encoder
« Reply #25 on: October 17, 2023, 04:57:09 pm »
Offline Rdx
« Reply #26 on: October 18, 2023, 03:44:58 pm »
There is this one, and it ships to pretty much everywhere (I think it is the same seller):
https://www.ebay.com/itm/325838697537
On the topic of the encoder itself: I assume there must be an actual mechanically moving element inside that switches the square wave to either output depending on its roation direction. I imagine it being a slip ring that gets dragged along switching in either output. Seems like a pretty sketchy and unreliable thing. But hey, at least your software will be simpler if the rotary switch does not make you read A/B signals  :P
« Last Edit: October 18, 2023, 03:49:45 pm by Rdx »
Online Peabody
« Reply #27 on: October 18, 2023, 04:01:11 pm »
I was wondering whether this type of encoder might be better than normal ones, at least as far as reading them is concerned.  But of course their physical construction would be more complicated.  But it seems they would be more difficult to deal with when it comes to software debouncing.  The interplay of the two switches in a normal encoder lets you deal with debouncing pretty easily, but with these there's nothing to distinguish a bounce from a real movement.
Offline EEVblogTopic starter
« Reply #28 on: October 19, 2023, 02:47:21 am »
FYI:
The following users thanked this post: fmashockie
Offline fmashockie
« Reply #29 on: October 19, 2023, 02:22:44 pm »
Thanks for tearing it down Dave! Really neat.  I am not a big fan of that design.  It just seems too easy for those actuators to get bent out of shape (as it did in your case).  And yep makes perfect sense why the contact cleaner did nothing!
