It looks like part of the motor overcurrent detect circuit. A jammed drive, or going past the limit switch might have happened, or the big shunt resistor went open circuit. The cut trace by D9 looks hokey.
You could figure out the value if that portion is sketched out, but the opto is likely damaged too.
