Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Help with part ID
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help with part ID (Read 859 times)
scrubba
Contributor
Country:
Help with part ID
on:
January 13, 2021, 06:35:44 pm »
Having trouble identifying and locating source for electronic component from a sewing machine. It looks like a mini transformer and only marks on it read TYP 90 40/96. Any help would be greatly appreciated. Thanks for reading.
Logged
bob91343
Super Contributor
Country:
Re: Help with part ID
Reply #1 on:
January 13, 2021, 07:39:05 pm »
Common mode choke?
Logged
scrubba
scrubba
Contributor
Country:
Reply #2 on:
January 13, 2021, 08:13:18 pm »
I'll try researching common mode chokes. Thanks for your input.
Logged
Grandchuck
Frequent Contributor
Country:
Reply #3 on:
January 13, 2021, 08:54:32 pm »
Common mode chokes are often used to suppress line noise. They are used in conjunction with two more capacitors. This looks different to me. But, I don't have a better idea.
Can you determine what it is connected to?
Logged
scrubba
scrubba
Contributor
Country:
Reply #4 on:
January 14, 2021, 12:51:59 am »
Thanks for your help. The traces from the four pins of this component lead to resistors, a capacitor, and a diode. (as far as I can tell with my limited knowledge)
Last Edit: January 14, 2021, 01:02:53 am by scrubba
Logged
scrubba
Contributor
Country:
Reply #5 on:
January 14, 2021, 12:59:02 am »
One more pic from the other side ...
Logged
bob91343
Super Contributor
Country:
Reply #6 on:
January 14, 2021, 01:06:08 am »
It appears that the component designations are marked on the board. Is there one for this component? Often the prefix is a clue. Q = transistor, R = resistor, D = diode, etc.
Looks like U145...
Last Edit: January 14, 2021, 01:08:10 am by bob91343
Logged
scrubba
Contributor
Country:
Reply #7 on:
January 14, 2021, 01:09:10 am »
I think it's U145.
Logged
JohnnyMalaria
Super Contributor
Country:
Reply #8 on:
January 14, 2021, 01:16:57 am »
Looks like this board (top left):
https://www.drdanessmh.com/berninahelectronbds1.html
You can buy the service manual for $12:
https://berninamanuals.com/Bernina_Service_Manuals.htm
Logged
scrubba
scrubba
Contributor
Country:
Reply #9 on:
January 14, 2021, 01:29:26 am »
Thank you for your suggestions and links. The board pictured says its for a model 1090. I'm not sure if it'll work for a 1260 which is what I'm trying to repair. I have also looked at boards for a model 1230 on ebay, which are similar, but have slight differences in the circuitry.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Help with part ID
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
