Author Topic: HELP Finding Rotary Encoder  (Read 4355 times)
Offline EEVblogTopic starter
« on: October 15, 2023, 09:01:18 am »
I can't find a match for this faulty rotary encoder. Early-mid 90's vintage.
Any leads appreciated. Thanks.
No markings on it. Come from a swiss bit of kit.
« Last Edit: October 15, 2023, 10:35:35 pm by EEVblog »
Offline floobydust
Re: HELP Finding Rotary Encoder
« Reply #1 on: October 15, 2023, 09:14:38 am »
need a pic
« Reply #2 on: October 15, 2023, 09:24:54 am »
Offline floobydust
« Reply #3 on: October 15, 2023, 09:30:52 am »
No, the post is only some text. No attachment.
« Last Edit: October 15, 2023, 09:33:04 am by floobydust »
Offline DavidAlfa
« Reply #4 on: October 15, 2023, 09:33:26 am »
Pic working here. Indeed very weird pinout!
« Last Edit: October 15, 2023, 09:35:34 am by DavidAlfa »
« Reply #5 on: October 15, 2023, 09:43:36 am »
The pic is an inline URL. That's the first time I've heard of inline external pics not working.
https://pbs.twimg.com/media/F8dv97rbQAAEd6W?format=jpg&name=900x900
« Reply #6 on: October 15, 2023, 09:44:13 am »
Yep, I can't find anything close.
And yet another repair video I can't complete because Murphy bites me on the arse.
Offline Peabody
« Reply #7 on: October 15, 2023, 02:00:45 pm »
I can't see any pic in the original post either.
Edit:  I'm running Windows 10, and the picture does not appear in Firefox, but does in Edge.  Can anyone suggest what setting I can change in Firefox to get this to work?  I assume it has something to do with recent work done on inline images.
Edit2: I see the picture in Firefox if I turn off Advanced Tracking Protection for EEVblog/forum. So apparently Firefox doesn't like the link to the picture.
Edit3:  What's odd is that the link shown in post #5 is visible, and the picture comes up when I click on it.  But the picture still doesn't appear in post #1 unless I turn off tracking protection.
« Last Edit: October 15, 2023, 02:43:51 pm by Peabody »
The following users thanked this post: EEVblog
Offline Zenith
« Reply #8 on: October 15, 2023, 02:12:03 pm »
A drop in new replacement is always the best and easiest way to go.
You might be able to take that apart and repair it. it doesn't look as if it's intended to be taken apart and it may require some surgery and gluing back together.
You may be able to use something else with the same functionality but a different pinout and bodge a connection with wires.
Online coromonadalix
« Reply #9 on: October 15, 2023, 02:32:02 pm »
the 2 small pins must be the shaft push switch
and on each side (bigger ones),  the 2 pins  must be a switch and the other 2  the second one   ???
weird indeed
Offline fmashockie
« Reply #10 on: October 15, 2023, 03:56:05 pm »
I assume you already tried resurrecting it with contact cleaner?  It looks to be a mechanical encoder which means some dirt in there is likely blocking the conductive traces or disk.  If you can't penetrate the internals with contact cleaner, why not try taking it apart to clean it as someone suggested? You've got nothing to loose at this point.  Could also make for an interesting video!
Online wasedadoc
« Reply #11 on: October 15, 2023, 05:12:13 pm »
Are those dome heads in the four corners cross-head screws?  Photo isn't clear enough to be certain one way or the other.
Offline DavidAlfa
« Reply #12 on: October 15, 2023, 06:58:24 pm »
Looks sealed / glued. Any attempt at opening it will probably end in your trash bin.
But if lucky, maybe it's only the 4 plastic rivets holding it.
« Last Edit: October 15, 2023, 07:02:07 pm by DavidAlfa »
Offline floobydust
« Reply #13 on: October 15, 2023, 07:28:56 pm »
I think it's basically a custom hen's tooth. I could not find the manufacturer. Pic of the topside could add more info.
Modern parts, instead of pins exiting under the middle, the encoder PC board is extended sticking out and the pins come out there.
Looks like Bourns ECW but EPS has the push switch.
Original bolts to the front panel, so the PCB doesn't give much support?
If I loved the piece of test equipment, I'd make an adapter PCB and fit a newer part (they are thinner, smaller, even slim SMT)- assuming the quadrature switches share a common on the main board.
The old part died from either wear or oxidation, so in desperation I would flood it with PPE to see if that fixes it. But it's plastic bushing and shaft so not a long life part in the first place. Or it got bashed.
Remote image loading issue appears to be due to private browsing, tracking protection: 'The resource at “https://pbs.twimg.com/media/F8dv97rbQAAEd6W?format=jpg&name=medium” was blocked because content blocking is enabled.'
This is on a few browsers I tried, unless I go directly to the URL.
The following users thanked this post: fenugrec
« Reply #14 on: October 15, 2023, 09:01:21 pm »
Maybe that's a new change to Twitter that is mucking up with browser protections?
Offline Peabody
« Reply #15 on: October 15, 2023, 10:26:54 pm »
I've never used Twitter.  Is pbs.twimg.com a Twitter link?
« Reply #16 on: October 15, 2023, 10:32:28 pm »
I presume so because I just dragged the photo into the Twitter post.
« Reply #17 on: October 15, 2023, 10:33:08 pm »
Top side.
The following users thanked this post: coromonadalix, Kaluluka, fmashockie
Offline DavidAlfa
« Reply #19 on: October 16, 2023, 08:37:39 am »
Ahh "Drehimpulsgeber" how didn't  I try that! :-DD
Offline Kaluluka
« Last Edit: October 16, 2023, 11:12:22 am by Kaluluka »
Offline fmashockie
« Reply #21 on: October 16, 2023, 02:46:17 pm »
After watching video and seeing the symptom I can see why he didn't consider penetrating with contact cleaner.  I would have still tried dousing it with DeoxIT  :horse: :-DD
Offline Peabody
« Reply #22 on: October 16, 2023, 03:01:33 pm »
So if you didn't want to spend the time and money to replace it with the same item, how would you rig something up to duplicate the function using one or more regular rotary encoders?  You could use one of those 10-cent MCUs to service the regular encoder, then regenerate the ouput on two of its pins.  But is there any more direct way?  I can't think of one.
« Reply #23 on: October 17, 2023, 01:31:08 am »
I did, it didn't do anything.
The following users thanked this post: fmashockie
« Reply #24 on: October 17, 2023, 01:31:50 am »
