Author Topic: Help identifying a component - M091 SOT23 (?)  (Read 2866 times)
Offline NexxenTopic starter
Re: Help identifying a component - M091 SOT23 (?)
« Reply #25 on: April 11, 2023, 10:20:27 pm »
I don't have a fuse, could I put a schottky diode instead? Or a resistor?
If the component I found on another motherboard is compatible with this, it's just a gate + a diode.
Soldering a diode between +5VSB and Drain isn't gonna be the same then?
What is the value I should try, for a diode? I have a few of those.
Thanks in advance!!
« Reply #26 on: April 14, 2023, 01:15:28 am »
Some news:
- I soldered a copper wire from +5VSB to the Drain of the missing sot-23
- tried to power it on but nothing
In the apst days I found some videos on YT explaining how power on works and poked around with my mulimeter.
I decided to probe the crystal oscillator involved in the process of power on and it actually powered on.
Keeping the probe on the + lead of the OSC makes it go full POST until boot media missing error.
At this point I don't know what to do. Check the OSC?
« Reply #27 on: April 14, 2023, 04:04:23 pm »
The RTC OSC deosn't short.
The two vias to the SB have each a Cap, one shorts to G. Once removed still have a short to G. SIgnals are ICH_RTCX2 and ICH_RTCX1
Same circuit on another board R to G are 8M ohms and 3Mohms;  on this board it's 7.7Mohms and 0.
Board powers on at random.
I'll check the 3V battery circuit.
« Last Edit: April 14, 2023, 04:30:16 pm by Nexxen »
« Reply #28 on: April 15, 2023, 12:36:47 am »
Issue wasn't the crystal.
Something else isn't working, until I get a new sot 23 it'll be on hold.
Too bad as it did boot and load linux via usb.
« Reply #29 on: October 19, 2023, 03:49:47 pm »
To close this case:
the SB was indeed faulty, first it had the Xstal 32KHz getting a variable amount of current at different voltages.
Even if it posted a few times it was a matter of time to have it dead.
It did provide a good amount of spare parts that helped solve other issues on other boards.
End: a lot of time wasted learning, not much learnt. Partial failure  :--. Ok, now I feel better :) :-+
