Author Topic: help about multimeter UNI-T UT58C  (Read 1290 times)
Offline BENAMORMEDTopic starter
  • Country: tn
    • EEVblog Electronics Community Forum
« on: May 31, 2024, 04:53:07 am »
hello at all
after wrong use the multimeter become unusable
the problem is: multimeter continous beeping on AC or DC and Ohm
all musurement are false
but work in diod mod/buzzer
any help please
thanks
« Last Edit: May 31, 2024, 05:17:21 am by BENAMORMED »
Offline Overspeed
Re: help about multimeter UNI-T UT58C
« Reply #1 on: May 31, 2024, 06:45:53 am »
Hello
You need first to open it and search possible burned components or pcb tracks
Regards
OS
The following users thanked this post: neoOpus
  • Country: tn
« Reply #2 on: May 31, 2024, 09:53:06 pm »
hello evryone,
thanks for replay
i check the fuse is ok
diode , zener diode ok
No visual burned or damaged component
see attached photos
any suggestion for next step!
thanks for all
« Last Edit: June 01, 2024, 03:42:30 am by BENAMORMED »
Offline Poroit
« Reply #3 on: June 02, 2024, 03:19:53 am »
Did you apply AC Volts while the meter was on the Ohms Range?
  • Country: tn
« Reply #4 on: June 02, 2024, 09:20:24 pm »
Hello
Im not sure but may be yes
The buzzer work perfectly in beep mode when i connect the probe
But it beep constantly in the rest of range except the capacity
Any idea!
Thanks
Offline Poroit
« Reply #5 on: June 03, 2024, 08:31:15 am »
Most multimeters are damaged from users forgetting to switch ranges.
The fuses don't react quickly enough to prevent component damage.
If you were measuring Resistance and forgot to change ranges before measuring AC Volts then you have taken out a component in the Resistance network.
Similarly if you had your multimeter set to measure DC current and attempted to measure AC Volts, then you will take out a component in the Universal current shunt.
Offline Zenith
« Reply #6 on: June 03, 2024, 09:06:09 am »
The schematic for the UT58A is available on Elektrotanya.
https://elektrotanya.com/multimeter_ut58a_sch.pdf/download.html#dl
I think there are only small differences between the UT58A, B and the UT58C, which you have. I couldn't find a service manual, but having the schematic for systematic fault finding is a lot better than trying to work things out without one.
You didn't say what the abuse was. If it was applying mains voltage while on the resistance range, it could well have caused widespread damage, which may not be obvious.
It's always worth investigating, because often faults are easily fixed, but I suspect you will have to buy a new meter.
The following users thanked this post: Overspeed
  • Country: tn
« Reply #7 on: June 04, 2024, 01:51:58 pm »
hello
i check the part of buzzer ic 4011 and 358
all the resistance are ok
no short in capacitor
Offline alonsojar
« Reply #8 on: June 04, 2024, 09:39:15 pm »
Did you check for faulty (shorted) PTC's?
This is a common fail after misuse at least in flukes.
Good luck in your repair
J Alonso
  • Country: tn
« Reply #9 on: June 05, 2024, 08:24:37 pm »
hello
yes it's ok no short
  • Country: tn
« Reply #10 on: June 05, 2024, 08:59:22 pm »
hello
green point no beep
red point continous beep and fault mesurement
green and red sometimes beep sometimes no beep
can any one help to resolve this problem
Offline Poroit
« Reply #11 on: June 06, 2024, 08:06:20 am »
How did you test LM358 & CD4011?
Did you review component data sheets & measure signals on the various pins?
  • Country: tn
« Reply #12 on: June 06, 2024, 01:52:58 pm »
no not yet only the component related to the IC 358 et 4011 (resistance and capacity marked in red) and short test in the Pins
