Author Topic: Hello, help me identify burnt power supply elements Techsolo TP-730  (Read 289 times)
bte and 1 Guest are viewing this topic.
Offline trek1203Topic starter
  • Country: by
PFC - CM6805BG
Offline m k
Re: Hello, help me identify burnt power supply elements Techsolo TP-730
« Reply #1 on: July 14, 2024, 05:44:11 pm »
Pretty hopeless without a schematics.
J2 can be zero ohms jumper, R18 same as R19.
Bottom pair of transistors can be the same, but upper pair is something else.
R45 could be 581.
Quite a zap.
It can have taken with it some others also that have no external marks.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
Offline asis
  • Country: ru
« Reply #2 on: July 14, 2024, 07:45:16 pm »
Look at the standard diagram - it will be easier to navigate (page 14).
https://semiconductors.es/datasheet-pdf/938655/CM6805.html
Offline DavidAlfa
« Reply #3 on: July 14, 2024, 08:05:10 pm »
Probably the primary switching transistors shorted and the HV (300V+) went everywhere, pretty sure there're lots of other roasted stuff.
