The
Heathkit AR-2000 was a medium-high quality domestic tuner-amplifier, 2*20W RMS output into 8ohms, tape + mag phono + ceramic phono inputs, and an LW/AM/FM and SW tuner.
When I was young in the early 1970s and "Hi Fi" music was a hot topic, my parent's 1950s mono record deck and valve Heathkit amplifier weren't cutting the mustard any more. So my father and I assembled a Heathkit AR-2000 tuner-amplifier together as a project over the Christmas holidays. I'd stuff the boards during the day, he would check them after work, and I would solder them. ISTR buying an Antex 25W soldering iron for the job - standard decent quality at the time.
I've recently "repossessed" the AR2000, and decided to see if it would work and how good/bad my assembly skills were.
Summary:
- the front panel LES bulbs had mostly failed. Easily replaced, thanks to fleabay
- a 100mA fuse had blown, but since it was only carrying 25mA, I just replaced that
- it appears to work (with a 40us risetime!), but I haven't connected it to loudspeaker
- shame about the scuffed cabinet
- the scale illumination is as uneven as ever, but that was normal then
- the soldering isn't bad, and certainly nowhere near the (lack of) quality that some Heathkit gorillas perpetrated!
