Author Topic: Dynatech Nevada Model 625 Function Generator, No Output  (Read 836 times)
Offline TyriendaTopic starter
« on: May 19, 2024, 05:24:57 pm »
As said up in the subject, said function generator is on my own table being fixed and figured out for own use. But it starts itself up in Remote mode, and as far as my own observation goes, the IEEE-488 is empty. Couple button clicks gets it so it won't lock itself up, and at no point i've gotten anything out from front panel Main out, or the back panel one. I'm not ruling my own errors in operating it, but i think i should have gotten it to output something, at some point. Getting lights to lit up in same spots as the one in Ebay i have been able to do, but there's absolutely nothing in the outputs. How to proceed with this? If it matters, serial for this is 019. Also new member in forums, but probably best chance to find something in form of information and help with this function generator.
Re: Dynatech Nevada Model 625 Function Generator, No Output
« Reply #1 on: May 20, 2024, 06:55:03 pm »
Starting to suspect that the bigger problem of this is with the person trying to operate it. Starting to see output out of this thing, or my oscilloscope is showing something, i can call that progress.
Offline m k
« Reply #2 on: May 31, 2024, 12:15:46 pm »
So after about a year you have an output?
If you measure something else, is the scope screen different or the same?
I think you've found some sort of a record, of unknown.
My prediction is that there must be a GPIB controller installed or some internal signals go wrong.
« Last Edit: May 31, 2024, 05:12:51 pm by m k »
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline m k
« Reply #3 on: June 02, 2024, 01:18:53 pm »
So Fluke Biomedical.
Maybe it's a lost cause for a manual of your machine.
« Reply #4 on: July 06, 2024, 12:49:21 pm »
Oscilloscope i have, it's 2-channel and i have Velleman's usb function generator that i can use to make signal i can compare with what that Dynatech is feeding out. I've taken time off that project as i felt i was hitting my forehead on a brick wall. Learning how to use that properly and figuring out if the process i need to go to get it to output has something to do with internal faults if there are some. When i got that, and was trying to get it to work, i was unable to get anything out of it and after a moment it locked itself up. I've been able to get it to output something, however changing waveform doesn't seem to currently do anything.
Offline m k
« Reply #5 on: July 06, 2024, 06:55:36 pm »
Open it and take few pictures.
Maybe somebody has seen it elsewhere.
