Author Topic: HDD faulty electronics  (Read 7677 times)
Offline kamtarTopic starter
« on: July 20, 2015, 04:46:29 pm »
Hello,
I have some problems with a hardrive WD5000AAKX. My conclusion is that it is a problem with the harddrive electronics.
I'm getting some timeouts, after which system tries to issue a reset into HDD, this helps but after few seconds the harddrive is again unresponsive, it takes 10-20 software resets to fix it or complete reboot.
Most of times reboot helps but sometimes HDD isnt recognized by BIOS and i have to do few more reboots to get it working. And I'm unable to see any pattern in when this timeouts appear.
It seems that:
            There is no problem with sata controller (other HDD works fine, but it is only a SATA I)
            There is no problem with OS, i have tried few reinstalls of W8 and W7. The only diffrence is that in W7 harddrive is switched into PIO mode after timeout.
            There is no problem with mechanical side of HDD - I have done few complete tests and no problems/ no bad sectors.
My question is: Could this be because of faulty electronics? And if so have someone some ideas? There is some generic 128MB RAM IC, do you think that its possible that some faulty memory places could be the cause here?
The harddrive is without warranty but it would be nice if i could fix it just with few bucks component.
btw. I have tried to reflow it with hot air just for fun but nothing.
Offline kripton2035
Re: HDD faulty electronics
« Reply #1 on: July 20, 2015, 05:36:49 pm »
entry level hard drive... more than a year... don't even bother with repair, buy a new one around 55 euros
it will cost you less than the time you will spend trying to repair it...
« Reply #2 on: July 20, 2015, 05:44:13 pm »
not everything have to be racional and about money/time. Maybe somebody want to do it just for fun and experience?
Offline con-f-use
  • Country: at
« Reply #3 on: July 20, 2015, 05:47:55 pm »
See if it's an easy problem, bad connection on the USB, gone electrolytic cap or the like. Should take you 5 minutes. If it's not throw it a way.
Offline retrolefty
« Reply #4 on: July 20, 2015, 07:20:59 pm »
May not be your problem but I often had problems on my prior desktop PC (once or twice a year) when suddenly the system would not recognize the SATA DVD drive and sometimes also on a second hard drive and rebooting or powering off and on would not fix. The usual fix for me was to unplug the SATA cable from both ends and reinsert a couple of times. That would always make the problem go away till the next time.
Online Monkeh
« Reply #5 on: July 20, 2015, 07:24:35 pm »
There is no USB or electrolytics involved here..
Offline helius
« Reply #6 on: July 20, 2015, 07:42:45 pm »
If you can find the same model drive you can try a pcb swap. It's pretty easy to do, you don't even need to open the environmental seal of the disk. All depends on how much the data is worth...
Offline kripton2035
« Reply #7 on: July 20, 2015, 07:43:51 pm »
Quote from: kamtar on Today at 04:44:13
yes but in that case you have 95% chance to end with a bad IC with no available equivalent
no schematic - no most available part to replace... sorry but even for fun it's not something I would follow ...
by the way did you put it in another computer and experience the same failure ?
that's the first thing I would try, reproduce the failure somewhere else.
« Reply #8 on: July 20, 2015, 08:44:19 pm »
Yes i tried it in other computer.. And there is no need for saving data, disk works fine this issue is occurring only temporarily. I just wanted to know if there is some real possibility for "modern" RAM IO (http://www.esmt.com.tw/DB/manager/upload/M13S128168A%282N%29.pdf) to have bad some memory location.
Online Monkeh
« Reply #9 on: July 20, 2015, 08:51:32 pm »
Er, sure, but you can't just pin it on the RAM.
The disk is unreliable, what gives you the impression your data is safe on it?
Online wraper
  • Country: lv
« Reply #10 on: July 21, 2015, 01:16:33 am »
Did you try to use it in another computer? Did you try to connect it to different SATA ports - SATA-2 / SATA-3?
The fact that some HDDs work ok with particular controller doesn't mean that controller is OK, especially if those HDDs are of older type with previous SATA revision. Also SATA cables tend to die causing some strange and intermittent issues. If using HDD on with the SATA-3 port, you should use appropriate cable too which is specified for SATA-3 operation (usually black color). Red and yellow cables shouldn't be used with SATA-3. Trying to use newer HDDs with very old sata controllers can cause some strange stuff (have seen that). FYI some of the Intel chipsets from Sandy bridge time had silicon bug which caused sata 3 ports to die. Post the SMART data here.
The normal fix would to throw a cable in the trash can. If such cable was used with HDD, it very likely it would cause "UltraDMA CRC Error Count" to grow in the SMART.
Online Monkeh
« Reply #11 on: July 21, 2015, 01:21:33 am »
You what? The colour means nothing (btw, I have red, blue, black, and orange cables.. and have seen grey, yellow, green, white...), and SATA 3.0 did not introduce any new cable requirements over SATA 2.0. As far as I know, nor did SATA 2.0 over SATA 1.0!
Online wraper
  • Country: lv
« Reply #12 on: July 21, 2015, 01:28:28 am »
:palm: Disk works reliably... Until the next day it isn't recognized anymore at all and all of your data is gone.
Online wraper
  • Country: lv
« Reply #13 on: July 21, 2015, 01:31:54 am »
Yes it did introduce new cable. Often motherboards come with both types of cables. SATA-2 cables will work fine with SATA-3 speed, but not guaranteed. Yes they are of various colors, but unless fancy stuff, SATA-3 cables usually are black and marked with text. Older cables more often are red and yellow and sometimes black too.
« Last Edit: July 21, 2015, 01:39:09 am by wraper »
Online Monkeh
« Reply #14 on: July 21, 2015, 01:35:39 am »
I would appreciate a reliable source for this. I'll give you mine:
https://www.sata-io.org/system/files/member-downloads/SATA-6-Gbs-The-Path-from-3gbs-to-6gbs.pdf
By allowing SATA 6Gb/s systems the ability to utilize the same connectors and cables as SATA 3Gb/s systems, most of the modifications required to achieve 6Gb/s are confined to the PHY layer. Except for doubling the data rate, the PHY is no more complex than that defined by the SATA Revision 2.6 specification. Changes to the protocol itself are minor, and the physical connectors and cables remain unchanged.
https://www.sata-io.org/system/files/member-downloads/SATA-6Gbs-Fast-Just-Got-Faster_2.pdf
In addition, SATA Revision 3.0 is backward compatible so that the same connectors and cabling used for SATA 3Gb/s under SATA Revision 2.6 can be used for SATA 6Gb/s.
etc etc.
Additionally, at the bottom of this document you'll find SATA 3.0 cable specs.
And in this one from 2003, ie. SATA 1.0, you will find.. exactly the same specs! Shocking.
« Last Edit: July 21, 2015, 02:29:59 am by Monkeh »
Offline fluxcapacitor
« Reply #15 on: July 21, 2015, 02:25:55 am »
Try scanning the drive with MHDD ,if youve got an old motherboard with IDE buy a SATA to IDE adapter. The WD5000AAKX has known problems with ROM and SA (service area) corruption. You could try a donor pcb and swap the rom.
http://forum.hddguru.com/viewtopic.php?f=1&t=26722
Offline poot36
« Reply #16 on: July 23, 2015, 05:21:41 am »
Have you tried updateing the drives firmware?  On some models of 500Gb drives I remember that there was an improperly programed lookup table and when that filled up the hdd stopped working.  You had to unbrick it using a programmer cable and some fancy pin isolation on the drive head to drive motherboard header.
Offline samnmax
« Reply #17 on: July 24, 2015, 09:35:03 am »
I think you mean the Seagate Barracuda 7200.11 series.
Online wraper
  • Country: lv
« Reply #18 on: July 24, 2015, 10:04:57 am »
Yeah, should mean those Seagates, but the issue wasn't limited to 500GB only IIRC. Though, the root cause wan't the firmware issue but inferior quality actually. If some corruption of the disk surface occurred, HDD could lock out due to the firmware bug. Even if undricked, only idiot would use it later as it would soon die anyway. I have two such 500GB Seagates laying somewhere, they didn't lock out but are full of bad sectors.
