You'll find a lot of opinions on this, but mine is if the scope is working, don't mess with it. This and other forums are littered with posts from people who attempted prophylactic recaps on working equipment and instead created a repair project.
I would say the only exception is if the RIFA cap is showing signs of aging, such as severe yellowing or fine cracking, then replace it. Or if there is a known history of RIFA failure on this specific model, replace it.
Optionally, you could verify your power supply voltages and ripple limits as described in the 2205 service manual. If any power rail is out of spec, then replace the filter cap(s) on that power rail and re-check.
