Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Kenwood KR-9400 No Stereo light in FM, no audio with FM mute on.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Kenwood KR-9400 No Stereo light in FM, no audio with FM mute on. (Read 788 times)
SAS73
Contributor
Country:
on:
November 06, 2023, 01:11:43 pm »
Dear friends,
I am trying to troubleshoot an Kenwood KR-9400 , low beacon voltage ( 0.78 VDC) Tested Qb7 and Qb8 seem OK. tried to adjust Lb5 , little more voltage after adjustment but not by much .
General question : What is exactly beacon signal does ? Is it just for a stereo light indicator, and FM mute circuitry ?
Thanks!
Logged
darkspr1te
Frequent Contributor
Country:
Re: Kenwood KR-9400 No Stereo light in FM, no audio with FM mute on.
Reply #1 on:
November 06, 2023, 02:04:03 pm »
On my old Kenwoods FM muting would mute NONE FM transmitted stations, so if you get no audio even on FM tranmissions with it on then its possible theres a issue the fm decode or seperation
look at board x04-104010 coming from FM IF board , it shows the stereo signal system. Also later on in the manual is shows the voltage readings for setting most of the VR's
this is from the manual found at
https://elektrotanya.com/kenwood_kr-9400-service-manual.pdf/download.html#dl
darkspr1te
Logged
SAS73
Contributor
Country:
Reply #2 on:
November 07, 2023, 12:38:27 am »
Thanks for reply !
I have a very good FM RF signal from antenna ( I had also tried signal generator) but if I press FM mute, no audio, probably because i don't have a 5 volts on TP5 terminal ( beacon), I had injected 5VDC to that terminal and FM mute works, the question is why I don't have 5 volts on that terminal?
I had tested all transistors and diodes on IF board. All tested good.
Last Edit: November 07, 2023, 01:47:35 am by SAS73
Logged
darkspr1te
Country:
Reply #3 on:
November 12, 2023, 02:37:28 pm »
Did you download and read the service manual I posted?, i has a trouble shooting section that gives a flow chart of failure and what to check.
darkspr1te
Logged
SAS73
Contributor
Country:
Reply #4 on:
November 14, 2023, 02:10:16 am »
Yes, I downloaded SM, replaced HA1156 , realigned according service manual , receiving in Stereo now, FM mute works also , THANKS
Last Edit: November 14, 2023, 02:18:29 am by SAS73
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
