Author Topic: 3-pin Molex power header? (board mount)  (Read 626 times)
Offline SkidlzTopic starter
« on: September 22, 2018, 12:49:42 am »
Hey guys,
I'm building an old DIY computer from some design PDFs and it calls for a power header that I can't find. It's a 3 pin, .2" spaced Molex connector (common enough), but it's board mount.
I can't find any mention of this header outside of the image I've attached. Can it still be found, or should I give up and use something more conventional?
Thanks
« Last Edit: September 22, 2018, 12:53:37 am by Skidlz »
