Author Topic: Hantek DSO2C10 TRIGGER  (Read 327 times)
Offline hantek2024Topic starter
« on: July 22, 2024, 02:45:39 pm »
Hello, greetings, I would like to know if the Hantek DSO2C10 Digital Oscilloscope or any of the models in the same series, solved the problem they had with the trigger, which apparently was very unstable.
Has the problem been solved with a firmware update?
Offline Aldo22
Re: Hantek DSO2C10 TRIGGER
« Reply #1 on: August 03, 2024, 10:55:05 am »
What problem are you referring to exactly?
It might be better to use the main threads of this model for questions:
https://www.eevblog.com/forum/testgear/hantek-dso2x1x-models-master-thread/
https://www.eevblog.com/forum/testgear/new-hantek-dso2x1x-models/
