Author Topic: Hantek IDSO1070A li-ion charging circuit  (Read 505 times)
Offline Southpole560Topic starter
« on: May 09, 2021, 03:47:20 pm »
Hey everybody, I'm new here and I'm not sure if this is the right place to post this but would anyone happen to know what type of MSOP-10 chip is used on the Hantek IDSO1070A ? It looks to be the charge controller for the li-ion battery but I cannot read the markings on it because it was fried somehow. I think I accidentally made a ground loop and took that chip out. The rest of the scope looks fine it's just that chip I need to replace. I looked at a MCP73833 and a LTC1733 datasheet but I'm not sure if either are those would be the right choice. Thank you for your help!
« Last Edit: May 09, 2021, 03:48:54 pm by Southpole560 »
Re: Hantek IDSO1070A li-ion charging circuit
« Reply #1 on: June 22, 2021, 09:54:17 am »
Bump. Anyone?
« Reply #2 on: July 03, 2021, 09:54:24 pm »
I finally figured out which charging circuit would work. It is a Texas Instruments BQ24090DGQT. So if anyone has the same issue, this fixed it.
The following users thanked this post: fzabkar
