Here are the pics.
One of the via's was corroded, had to run a jumper through and run to the 104 resistor that connects to the IC, once this was done the fob leds started blinking again.
The 393 resistor near the p21 transistor seemed to have a crack on it that's why it looks funny as i removed it to inspect it better, it measured fine and was put back in.
When i was probing with tweezers around that area i could see the RF signal on the SDR it was very weak however, which leads me to believe the signal was getting to that p21 transistor which i can only assume is being used as an amplifier, but now i cant even get it to do that, must have killed something in the process.
